Brief Description: Installed Comm Antenna into Right Winglet
I Installed my Comm antenna into the Right winglet. I measured out the Rudder cut out and then positioned the Antenna to not interfere with the Rudder cutout. I installed to Antenna Coax and then removed foam to embed the antenna into the winglet. I mask off the Foam and installed the Antenna into a bed of Micro using nails to hold the Antenna in place (these will be removed after the Micro cures). I then topped the Antenna with Micro and placed Peel ply over Micro'ed areas.
