BEZJet Build
BEZJet
Fitting Front Canopy Deck
I adjusted the canopy latches to pull up the canopy. I then used Flox to create a close gap seal and carved a Drip rail into the deck and installed 1/4" Al tubes to leach water out of drip rail. Cloased it all up and cured it.
Using Flox to get a good Fit
Carved out Drip Rail
Closed up and curing
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
