Brief Description: Installed Longeron Hardpoint Mounts for pneumatic
Mounted Hardpoints onto Longerons in thin layer of flox... also drilled holes on either side of nut and filled with flox. I then layed up 2 plys of BID @ 45 deg, applied Peel Ply and vacuum Bagged both sides. Spent 2 hrs chasing vacume leaks but finally got a good vacume pulled. I then used heat lamps to help cure the layup over night.
