Brief Description: Cutting and Removing Plexiglass
All inside layups complete... cut and removed rollover center section plexi glass and prepaired area for outside Foam and Layup. Used an Abrasive cutting wheel to carefully cut thru the Plexiglass without cutting into the composit layups under the plexiglass. Once cut, the Plexiglass came right off with very little effort due to the preperation of the inside surface with peelply.
