Rogers Web Site
Date:  5-6-2014
Brief Description:  Port aileron.
I copied the washer arrangement from the starboard aileron to the port. and connected the port aileron control rod. I found it easier to do this with the inner aileron hinge disconnected connecting the aileron control rod and then connecting the aileron inner hinge.
I made a start on the port flap hinge. I cut off the lugs that I needed to remove, to allow me to use the two hinge pin system coming from the centre of the flap hinge.
