My RV-8 Build Log
RV-8
EL Trim Tab Motor Fitting
EL Trim Tab Motor Fitting, trimming the plate to fit the EL skin nicely. Tested the motor for travel, seems to work just fine.
Almost there - trimming the plate holding the trim tab motor
Trim Tab motor tested - works
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
