Test Fitting the Elevators. How many times did I hang the elevators? Lost count. It is critical to the the rod end bearing clearance correct, and to ensure the rod end bearing is sufficiently inserted into the HS rear spar. I made some little edge distance guides to ensure everything is correct and symetrical. I think it took 3 days to do this.
