I was only at the hanger a couple hours today but did manage to get another instrument hooked up. I first organized the P-Mag wires; I need to run grounds for the P-Mags from the engine case before I can make the connections needed.
I hooked up the connector for the manifold pressure sensor and then tested to make sure it reads correctly on the engine display, which it did.
