RV-7A Construction Log
RV-7A
Wing root wiring
The final thing to install the wing is the wiring interface at the wing root.
I installed the comm antenna first and plugged in its wire.
I twisted the connector into place and pulled the foam installation into place.
I added a coax cable to the VOR antenna wire and plugged in the VOR antenna. It runs to the Garmin 430.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
