Fabricated a simple angled holding bracket to support a conduit clamp for the magnetometer's CPC connector. I did not like the way the wiring would have laid within the wing structure had I just bundled it with lacing ribbon so, another solution was needed.
The assembly is secured to a rib by using #6x1/2" socket head screws & friction nuts. Using the screws in lieu of blind rivets will allow for easier maintenance of the magnetometer & connector; should they need to be replaced.
