Peters Web Site
Sling4
GPS Antenna Mounts and Shunt.
Mounted the two GPS antenna mounts and the shunt.
I wanted to use the two holes in the firewall that I had drilled for the RADAC ( which I'm not using ).
Using two exsisting holes.
Hope this works OK.
GPS antenna mounts and shunt.
Sling4 Home
3003
354
475
Firewall
Flight Controls
Flight Controls.
Front Windscreen
Fuel Tanks
437
87
87
Propeller
Propeller
49
87
Undercarriage
Undercarriage
Upholstery
Upholstery
Windscreen
207
