Peters Web Site
Sling4
Undercarriage
3-16-2024
Elevator Rigging.
KSC and I rigged the elevator, which is reasonable straight forward.
It is definitely a two person task, thank you KSC.
The elevator is now 30 degrees up and 20 degrees down.
The two limits are within .2 of a degree depending on how you breath.
Elevator zero.
Twenty degrees down.
Thirty degrees up.
Sling4 Home
3003
354
475
Firewall
Flight Controls
Flight Controls.
Front Windscreen
Fuel Tanks
437
87
87
Propeller
Propeller
49
87
Undercarriage
Undercarriage
Upholstery
Upholstery
Windscreen
207
