Peters Web Site
Sling4
Fuel Pumps.
Spent time wiring the fuel pumps.
Main fuel pump wire is longer, Aux. fuel pump wire is shorter.
Will not be able to connect the wiring to the incorrect pump.
Positive terminal is a 4mm ring connection and negative terminal is a 5mm ring connection.
Fuel pumps.
Fuel pumps.
Fuel pumps.
Sling4 Home
3003
354
475
Firewall
Flight Controls
Flight Controls.
Front Windscreen
Fuel Tanks
437
87
87
Propeller
Propeller
49
87
Undercarriage
Undercarriage
Upholstery
Upholstery
Windscreen
207
