-Cleco'd the upper cowl intake ramps onto the upper cowl and did a test fit. Needed to trim them a couple of iterations and then it fit fine. I need to research how the rubber seal interacts with the ramps before I do more trimming to the side baffles...more to come. In the mean time I started cutting patterns for the baffle seal on the rear and front baffles since they are set.
Upper cowl inlet ramps
If I seal the baffling to the new upper ramps I'll need to trim it as shown...need to look into this.
