ROBERT'S WEB SITE
RV7A
Vertical Stab
7-16-2011
Vertical Stab Progress
-Prepped VS frame parts (ribs, spars, stiffener) – part edges and fluted ribs
-Match drilled rear spar assembly holes (spar, stiffener, rudder brackets)
-Assembled VS frame
-Drilled Rib/spar attach holes
-Got the VS skin out of the box
Rear spar assembled and drilled
VS Skeleton assembled & drilled
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
Fuselage - Forward F
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
