Brief Description: Final assembly riveting started - 3
Next up was riveting in the two inner bottom skin angles. The only small challenge was the most aft set of rivets against the wing box bulkhead. The squeezer wouldn't fit and the offset rivet tool had an interference with the already installed and torqued bolt holding the F-783B cover support rib. So I put in LP4-3's.
