Brief Description: Final assembly riveting started - 2
Nexts up prior to final assembly is a single rivet to anchor each F-902 bulkhead to the lower longeron. This can't be done with the forward bottom skin on. I had to remake the first set of shims I fabricated to close the gap since the dimension changed slightly in the assembly.
