Brief Description: Bell Crank and Servo Bracket Riveting 1
First I riveted on the servo bracket (no pictures) with the squeezer.
Then I did a quick inventory of the nuts, bolts, and washers in the Garmin installation kit. The Garmin instructions call for a washer inbetween the bell crank arms where the push/pull rod connects. I put that in when I riveted the assembly together thinking it would get pinched in there for good, but it slid out after I removed the bolt.
Then I did a quick fit of the bell crank and push/pull rod.
