ROBERT'S WEB SITE
RV7A
Seat Ribs prep 6
I marked the rib cut out per the drawing using the flange edge and 2" dimension.
I used the band saw to make the cuts.
Edge finished
Mark rib for cutting
Band saw worked well for cutting ribs
RV7A Home
1152
Ailerons
Baggage Compartmet
Elevator
25
Firewall
Flaps
Flying
Fuel Tanks
89
211
Fuselage - Forward F
67
127
Fuselage - Mid Fusel
Fuselage Bulkheads
Fuselge - Aft Fusela
Horizontal Stab
Post Flip Fuselage
Rudder/Brake Assembl
Shop
Supplies
Training
Trim Tab
Vertical Stab
Wing Leading Edges
Wing Spars
