ROBERT'S WEB SITE
Date:  2-4-2016
Brief Description:  Left Flap riveting 6
I started out by drilling out and replacing the two bent over shop heads from the last session. No problems with these.
The FL706A and FL706B are joined with some standard solid rivets. These were easily done with the squeezer.
Next the outboard end rib was riveted with the squeezer. I could get all but the most aft rivet with the no-hole yoke. I used a pulled rivet here like on the right flap.
Lastly the bottom skin/spar/flap hinge line was riveted with the squeezer working from the inside out. Done with the flaps.
Sqeezing the 706A and 706B
End rib riveted
End rib riveted
Done!
Done!
