Brief Description: Left wing skin priming and right wing skin prep
The left outboard wing skin had some problems with the primer so I took care of that first. There were spots where the primer did not adhere to the aluminum and has a wrinkled primer appearance. I’ve seen this before. The fix is pretty simple and seems to work consistently: 1) scuff off the loose primer with a scotchbrite pad, 2) wipe down with lacquer thinner, and 3) re-prime.
I finished de-burring the right outboard wing skin, rolled the inboard edge, and dimpled most of the holes.
