ROBERT'S WEB SITE
Date:  4-19-2013
Brief Description:  T-405 Fab - right tank
Traced the mirror image of the left T-405 onto the right bracket. Same process as the left, rough cut on the band saw, bench sander, and then the scotchbrite wheel. I then cut notches for the shop heads in the rib.
On my Craftsman drill press, the drill speed is controlled by the configuration of the belts and pulleys. I set it on the lowest rpm it is capable of - 250. I then got out the fly cutter, found the center of the cutout for the left inboard tank rib and clamped it all up on the drill press. The fly cutter I got only goes up to 4" diameter, which isn't really big enough. The operation was a non event. It cut well. Kind of loud though. I opened the hole up some more with die grinder. There is still a bit of the rib stiffening bead left. The plans show the rib hole slightly smaller then the doubler ring, but many builders seem to cut it the same size. I think mine is OK. The remaining bead does not interfere with the access plate.
Mirror images
Mirror images
Notched and fit in each rib
No limbs were lost
No limbs were lost
