Alaskan Bearhawk
Date:  5-2-2020
Brief Description:  Fuel Tank Grounding Wire
The tank grounding cables are really easy. I just used 18GA wire. I cleaned a spot on a rib with a bonding brush and secured the ring terminal with a 6-32 screw. The other end gets attached to the tab that I welded onto each tank.
Cean ground point
Cean ground point
Wire in place
Wire in place
