Alaskan Bearhawk
Date:  12-10-2011
Number of Hours:  1.50
Brief Description:  Landing Gear Fittings Part 6
I got all the holes drilled to the 1/4in diameter. The final hole size will be drilled when the fittings are welded and the landing gear in place.
One thing I found was that I needed a new drill press vise. While drilling some of the holes in this thick plate the jaws would angle the piece a bit off vertical when I tightened it up...enough so it would make the hole the wrong size. Also, sometimes it wouldn't hold the correct way and it almost ruined the piece I was drilling when it let loose. I spent a LOT of time, too much actually, fighting the vise instead of making parts. The old vise had it, so I ordered a new one.
Christmas is coming, so are guests so this will probably be the last post until after the new year. Merry Christmas everyone and Happy New Year!!!
Holes all drilled
Holes all drilled
Trial fit
Trial fit
