Brief Description: Horizontal Stabilizer Mount Part 5
Once I determined the mount tube was exactly perpendicular to the centerline and level, I tacked both sides. After checking the measurements one last time, I disassembled all the rulers and line and finish welded the mount. It came out just the way I like it. It’s aligned perfectly in every axis and the parts fit is tight on the tube. I agree with Wayne Massey on his entry for the same mount on his project…this is one area you want to take the time to get right.
