I was able to get out to the shop for an hour and got the tailwheel aft mount welded. I got the plumb bobs all aligned and just had to tweak the spring about an 1/8th of an inch. Once it was set, I tacked it in place. After that, I took everything apart and started to weld the bracket to the structure. I was able to get it welded about halfway when it was time to quit. The next few days will be slack on the airplane, but I'll get back on it after taking care of stuff at home.
