Lots of odds and ends done today. I finished the tail wire bottom bracket and welded it in place. I did have a small issue in that the weld on the tube for the bolt where it exits the T11 cross tube didn't allow for the bracket to lay flat on the longerons. I talked it over with Bob for a few options and I ended up chamfering the inside of the hole to allow for the weld volume. I bent it to the proper angle shown in the plans welded it in place.
I also made the front strut brackets and drilled pilot holes in the spring bracket. I figure it would be much easier to drill the holes now than when it's welded in place. I am really glad I made the bracket an 1/8th inch wider on each side to accommodate the AN4 bolts that hold the bracket in place!
