I did the final welding of the rudder, including the mount for the tail light. I have to admit, it was a little booger to put in correctly, but I did it. Once I cut the tubing, I had to really pay attention to aligning the trailing edge. Once it was aligned, I quickly tacked it, and then tacked it a little heavier. I final welded the mount and it turned out straight. I also welded the rudder horn to the tail spar. I just put the completed rudder on the tail post to get an idea as to how it will look with a tail. Looks like an airplane...finally!!!
