Alaskan Bearhawk
Date:  12-6-2013
Number of Hours:  3.50
Brief Description:  Elevator Belcrank Part 1
I got some more time in the shop this evening. First I skip-welded the stop rings on the control stick assembly. Then I finished the work on the elevator belcrank halves. I drilled two 7/8ths holes using a step bit and cut out the middle between the two holes to make the oval hole in the assembly. I then smoothed out all the edges on both pieces.
Then came the tedious process of making six 3/8ths washers out of .050 and welding them in place. This is one job that I have to be careful of and don’t really care for. One thing I did was use clecos to hold the washers in place to tack weld them. This is the first time I tried this and it worked out great!
The heat control for the TIG is critical so I don't burn off the edges of the metal, but when I’m operating at that low of an amperage my auto-darkening helmet sometimes deactivates while welding or doesn’t activate at all. The plasma arc is still way too bright to look at and I have to stop or I may burn through the metal without knowing it. It was rather annoying and I saw plenty of blue spots, like looking into a flash on a camera when it goes off. Finally got it done. I’ll continue in the next few days by making the pivot and welding that to the fuselage. One more step!
Two clecoed together
Cleaned up
Cleaned up
Washers welded
Washers welded
