Alaskan Bearhawk
Date:  11-5-2013
Number of Hours:  4.00
Brief Description:  Control Stick Assembly Part 8
I spent most of the afternoon backtracking and making a new set of ring mounts for the control stick assembly. I welded them up, which distorts the big ring quite a bit despite my best efforts to control the heat.
After cleaning out the scale on the back side of the welds, I did the best I could to make the mount ring round again by squeezing gently in the vise and followed up with the air spiral sander and valve lapping compound. After a nice, smooth fit I marked and drilled/reamed the bolt holes to the final size and the bolts fit perfect and sit flat, just like they should. These turned out MUCH nice than the previous iteration. I bead-blasted the mounts and once the oil holes in the top I’m ready to weld the control stick pivot brackets to the main tube. That will hopefully be done tomorrow.
Lapping the ring
Lapping the ring
As per the plans
As per the plans
Two keepers, still need 1/8th oil holes
