Got the skegs done. I was able to TIG the offending holes closed and fit the new steel wear strips. I bent the new 4130 steel wear strip into shape, match-drilled and countersunk the rivets. I etched, primed and painted the steel. I beads blasted the skeg and gave it a fresh coat of paint with the Tempo silver laquer that matches the EDO paint. Job done x2.
