Based on what Jim Harden told me, there was very little surface area to glue fabric to around the landing gear fittings. I made and installed the plates, so the next thing to do is put a doily around each one. I measured all the dimensions and made a paper pattern. It fit fine, so I made the custom doily by using the pattern. I made two, one for each aft landing gear attach point. I made two more that were very similar for the front mounts.
