Brief Description: Fuselage Kit Arrives, continued
This software is limited to 3 photos per entry so I added another entry for today to included some pictures of the fuselage. These items sure do take up a lot of room in the shop. I plan to build a support structure with wheels under the fuselage so I can open the double doors, roll the fuselage outside when I need more room to work, and then roll it back in when I'm through for the day.
Right front side of the fuselage. The pieces in blue plastic on top are the ailerons and flaps.
Aft rear side of the fuselage,
Cockpit. The front is to your left and the control sticks go in the openings on the left.
