Brief Description: Initial Assembly of HS Understructure
Assembled the two HS spars and their ribs and drilled the rib attach holes. The 90 degree angle drill attachment came in handy to be able to get in the tight places. Disassembled the parts and deburred the holes. Not going to go any farther on the HS until I get the replacement splice angle that I ordered. Looks good to see the frame go together.
HS spars and ribs (minus the 4 center ribs which I can't drill until I get the replacement part)
