Brief Description: Pitot Mast and Inspection Plates
Finished up the pitot mast by drilling and countersinking the attach holes. Next I prepared the inspection panels fopr each wing. Drilled, de-burred and dimpled/counter-sunk the holes on the panels and also attached the nut plates to the edges of the inspection holes. Then I smoothed and finished the edges of the inspection panels.
Drilled the rivet holes that will secure the pitot mast.
Drilled, de-burred, dimpled and edge finished the inspection panels
Installed the nut plates that secure the inspection panels.
