This entry is the accumulation of several days of work- an hour here, an hour there.
Completed the many details for the aft fuselage. There is alot going on in the southern portion of the aft segment. This is another place a few more details/drawings would have made a world of difference. The order which you add these angles and assemblies is important as otherwise, you are constantly having to disassemble other assemblies to get things where they need to be. Sonex could really help by listing a workable order. What I've listed here is not helpful.
Fabricated spacer for tail wheel mount. Added the aft lower mount ot the lower vertical fin post. Placed the aft bulkhead; F23-02. Placed the lower mount angel; F23-04. Placed the Fwd lower mount angle: F23-03. Placed the aft angle piece F22-05. Placed the aft shear web assembly: F22-02. Drilled the lower skin. Placed F23-11 and F23-09 the fwd and aft pushrod support assemblies (still need to insert the snap bushings after they are cleaned up and primed).
Updrilled the splice plates for the AN 525 bolts. Updrilled all elements to #30 except the upper row on the fuselage side panels which await the turtle deck.
