Alaska Sonex
Date:  5-1-2010
Number of Hours:  8.00
Brief Description:  Tail Install
Mounted the horizontal and then vertical stabilizers. This required a great deal of trial and error fitting with significant amounts of filing and sanding. Reaching the furthest of the bolts/nuts on the vertical tail spar was painful. That thing is not comming off. I will still need to complete the fairings but will get those a bit later.
It took a bit of filing to get my elevators to the correct up travel. All is well now.
Vertical stab spar.
Vertical stab spar.
