Broke down the wing skins and cleaned/deburred all final sized holes. Located and drilled the Tiedown eye bolt insertion.
Dimpled all forward (nose) ribs. This required modification of my dimple die as it was too large to seat properly- could not get close enough to the rib surfaces. I ground off a goodly portion of the female die and this worked perfectly. I hadn't heard of this being a problem for others -perhaps I have abnormally large dies. My rib holes were mostly right on the centerline.
