Woody's Web site
Cozy MK IV
Fuselage Assembly
1-26-2003
6.x
Glass for mouning Fuel Valve
This is the first minor design change. I'll be using the ANDAIR fuel valve PN FS20x3-M instead of the plans valve. This will require modification for mounting. The valve will be mounted to the plywood and a glass plate over it followed by the plate.
Pitts Model 12 Home
Cozy MK IV Home
977
Bulkheads
49
103
Canard
Canard Install
Center Section Spar
Courtney
Elevators
Fuselage Assembly
Fuselage Exterior
Fuselage Sides
Headrests, Heat Duct
Main Landing Gear an
Nose and Nose Gear
57
105
