Brief Description: Dishing of Control Stick depressions
Dished out the depressions for the control sticks in the sides. This is about a 1/4 in deep by 8 in radius on each side. Tried an experiment by cutting out a disk from 1/4 in plywood. Used the outer circle to keep the disk from walking. This worked but the bondo caused the foam to divit. Try clamping next time
