Redo of new instrument panel continues with cutting all glass for both side layups not including the stiffeners. The glass was cut to allow the side to be covered with single pieces for each ply. It also turns out that the UND is only above the leg holes so this piece should weigh less. Not bad that this part needed to be redone after all.
