Brief Description: install canopy hinges and 6mm ply harnes
install canopy hinges and 6mm plywood attach points. The hinges are actually ch18.2 but are done here so that the bolts can be accessed prior to installing the shoulder support. The 6mm plywood is installed on each of the outer harness attach points.
