Several things were done. The bottom was prepped. 3/8 Dinylcell Foam was joined and cut to size. I accidentally substituted 4.5lb last a foam with a lower desity on the edge buildup. Started cutting and installing the correct foam for the inside as well. Installed foam to level the all of the edges as well
