With the bottom panel laid out I cut the inspection holes using the jig. Next I predrilled the rib holes. I'm not drilling the end ribs or the aux tank side ribs yet. I'll double check the layout for those after I put the panel on the wing.
Cutting Inspection Holes
Two Extra "Practice" Holes At Aux Tank (I'll cut out later)
