Brief Description: Trim skin, installing stiffeners and pocket cover
"I pulled the flap and aileron hinges off the left wing and drilled and riveted the rod end bearings. I left the skins 1/4"" long in the flap area to trim to fit later (now). I figured after fitting the flaps I could make sure and have a good fit - well it turns out I need to trim off exactly 1/4 inch so I could have saved myself some time and done this originally.
After trimming the skins 1/4"" I started installing the skin stiffeners. I drilled and clecoed the top stiffener but decided to wait until the wing is back in the dolly to drill and cleco the bottom stiffener. I think it will be easy standing up rather than laying on my back locating and drilling holes.
Next I drilled the top of the aileron pocket covers."
