I did the final weld on the other 3/4" arm on the other support frame. For some reason this frame did not bend as much as the other one but I did heat and bend it back to straight. I then welded the cross brace on both arms.
I drilled out the 7/16" hole in the support frames for the cable pulley support piece. Then I welded the 7/16" tube in place and drilled it out to a 1/4" hole. The next thing I did was tack weld the other end on the support tubes.
That's as far as I got today because I ran out of Oxy. I noticed last time I opened up the tanks for the day that I was running low on Oxy. I figured I would run in Saturday morning during there weekend hours and get a new tank. Well, when I went in Saturday they had closed for the holiday weekend and don't open now until Tuesday. That's the second time I've run out now on a weekend. I don't plan to make it a third!
