I fit the spacer pieces for the #11 rib at the center splice plate. I finished fitting the nose rib attach angles then removed them and drilled the holes on the rib attach side of the angle. I drilled one hole on the end of the center rib attach angles.
I went skiing today - otherwise I would have gotten more done. :-)
