Brief Description: Finish drilling spar caps, deburr, prime prep
I assembled and clamped the right main spar to the table. The capstrips were drilled to #21 size holes. After the holes were drilled I disassembled the spar. I was concerned with the tolerance of matching the spar web holes - I want these to be right on with no elongated holes. The holes matched perfectly - no holes on the web were elongated.
I deburred the capstrips, cleaned, acid etched and alidine treatment.
