Brief Description: Match drill left side main spar capstrips
I match drilled the left main capstrips. Again just two at a time to a #40 hole then I stacked 4 and drilled about half the holes to #30. I also trimmed the ends off the spar webs and deburred them. I clecoed an end plate to the spar web as a reference for trimming.
All main spar parts are cut to size and match drilled now.
