Waynes Bearhawks
Date:  7-15-2012
Number of Hours:  7.00
Brief Description:  Trim tab drive
I'm all gassed up and ready to go! First thing I did was line up the trim torque tubes. I did have to cut the tacks on the inner bushing on both side to make a slight adjustment then I welded the bushing permanent. With the tube lined up I drilled and bolted the trim horns. Welded the 5/8 tube stops on. Welded the drive arms on the outer end. Welded the trim linkage to the trim tabs. Last thing I did was make the trim drive tube out of 5/16 x .028 tubing.
Trim Horn
Trim Horn
Trim Drive Tube
Trim Drive Tube
Tail Section Done!
Tail Section Done!
